Had a super M that acted like that. After cleaning screen at carburetor and carburetor twice I found out that there was some small pieces of chaff in bottom of gas tank. After being run for a while they would migrate to the valve above the settling bowl and restrict the fuel flow. Try removing settling bowl under tank and place can under valve. Open valve and see if you have a good flow coming out of gas tank. You might be able to check inside tank for floating debris by removing fuel cap and shining a small flashlight into tank.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
