340 utility questions
Posted by tesmith66 on December 26, 2007 at 04:53:02 from (66.117.99.74):
Merry Christmas!!
Just got a 340 Utility with an IH 200 loader and have some questions.
Where exactly is the serial number located? I have looked all over both sides of the clutch housing and found nothing.
It appears that the original color of this thing was yellow. It has independant (live?) PTO and a 3pt hitch, so is it a utility, industrial or ???
It has 24" wheels with 14" tires and weights. are these original to the industrial model? Should I replace them with 28"? I intend to use this as a manure/dirt/rock mover as well as for pasture mowing.
How does the 3pt work? It will only go fully up or down. Is there a way to switch it over to position control?
Sorry for all of the questions at once. I have been reading here a lot and just haven"t found the answers to these questions.
Thanks!!
