Re: Nebraska tests
Posted by Andy Martin on December 26, 2007 at 07:04:26 from (63.99.111.188):
In Reply to: Re: Nebraska tests posted by Bill in IL on December 26, 2007 at 06:33:04:
I had a friend ruin two good 327's by moving the same warped intake from one to the other. Burned up the same two pistons and cylinders in both.
I've had intake leaks on Farmalls with no adverse effects, and have never had a problem adjusting the main fuel screw.
Not only low compression, but also 1,500 rpm.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
