Re: Hydraulics on IH 350
Posted by ChrisAS on December 26, 2007 at 08:48:46 from (209.181.152.45):
In Reply to: Hydraulics on IH 350 posted by dhermesc on December 26, 2007 at 07:45:33:
That is what we mean as under high pressure. The first thing I wound check is the valve spools to see if one is half way between single and double action. To change bewteen single and double you just turn the spool of the valve a little. There is a roll pin through spool on top of the valve body. You will find this on right side of tractor in front of steering wheel. May have to take right hood off to be able to see it good.
