If you've got an electric hydraulic pump in the truck and the C has been converted to 12V electrical, you can just hang that off the tractor, wire it up, and use it just like you did on the truck.
You can also use the tractor's hydraulics by installing a bypass block and a two-spool open-center hydraulic remote valve. The cylinders on the plow aren't anything special. Just drain the old oil out of the cylinders and hoses before you hook them up to the tractor, as it may be incompatible with the HyTran in your tractor's system. You'll also need to refill the hydraulic reservoir on the C a couple of times as the air gets purged out of the hoses.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
