Re: IH 444 hydraulic/loader question
Posted by IH2444 on December 27, 2007 at 05:42:17 from (192.76.82.89):
In Reply to: IH 444 hydraulic/loader question posted by paridgerunner on December 27, 2007 at 05:08:49:
Umm a question.
Does the tractor have a front crank driven aux hydraulic pump ?
Anyway there are I think 2 or 3 drain plugs under the tranny and rear end.
And one in the back of the 3 point lift box on top of the rearend. the lift box gets refilled to the bottom of the fill tube (approx 3-4 gal).
The tranny and rearend get refilled at the plug beside the gearshift.
fill up to the plug just underneath the footboatd if the tractor only has one hydraulic pump, if 2 pumps on tractor fill to within 6 inches of top of fill opening.
