Re: IH 444 hydraulic/loader question
Posted by IH2444 on December 27, 2007 at 08:10:11 from (192.76.82.89):
In Reply to: Re: IH 444 hydraulic/loader question posted by paridgerunner on December 27, 2007 at 06:23:13:
Yep that is what I mean. I have the same setup.
You will fill until the fluid is 6 inches below the top of the fill opening beside the gearshift. about 17 gal I think.
I use the premium UTF from TSC. any fluid that meets HyTran specs should be fine.
I did not have to bleed mine when I changed it, just work the steering and loader and lift till they quit being jerky and noisy and you have the air out.
To measure mine I clamp a small stick in a pair of vice grips and use it to measure the oil level.
