Posted by MN Dave 2 on December 27, 2007 at 19:33:16 from (204.221.132.147):
In Reply to: Re: V8 farmall posted by gene bender on December 27, 2007 at 10:07:24:
I installed a 440 chrysler in a M. You will need to have the origional adapter plate drilled/converted to line up for the new motor. You will need to have a steel flywheel made as the cast flywheel won't take over 3000 rpms or so I've been told. You will have to use a electric fan as the v-8 will sit much lower in the frame than the stock.
My M has an estimated 400+ hp is very competative pulling at 6000 rpm with 18.4X38 tires.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our
... [Read Article]
