Re: Battery cable question
Posted by Nat 2 on December 28, 2007 at 10:14:27 from (64.80.108.52):
In Reply to: Battery cable question posted by perrycountyfarmalls on December 28, 2007 at 07:10:04:
Ohm's law is double the volts, DOUBLE the Amps if you use the same 6V starter. You get FOUR times as much power going to the starter. That's why a 12V conversion spins the tractor over so much better.
Mike, thicker cables are ALWAYS better. It doesn't matter what voltage you use. Thicker cables offer less resistance to the flow of electricity.
