Re: 47 A coil question
Posted by glennster on December 28, 2007 at 14:43:46 from (76.224.13.122):
In Reply to: 47 A coil question posted by AJ Clark on December 28, 2007 at 14:35:24:
if you have a 6v battery, its just a 6v coil without a resistor. do a little checking before you buy a new coil. if you have a test lite, turn the ignition on and place the test lite on the wire terminal on the coil that does not go in the side of the distributor body. it should lite showing the coil is getting power. if not pop distrib cab, see if points are open, if not, bump motor over till points are open and try again. it should lite. next, try taking the coil wire, (at this point i pull a plug wire, stick it in the coil and remove a spark plug and lay it on the motor) then with the ignition on, take a small screwdriver and short accross the points and see if you get a spark there and if the coil fires the spark plug. if it does, try cleaning the points with some 320 grit sandpaper. if it doesnt fire, then i would change the coil.
