Re: trailering an H
Posted by Norm in Alabama on December 28, 2007 at 17:12:39 from (12.201.101.57):
In Reply to: trailering an H posted by j440 on December 28, 2007 at 17:01:45:
Chain both sides of the front to the forward trailer frame on each side. Run a chain from one side of the trailer to the other across the hitch and use an adjustable load binder to get it tight. Also tie the front chain with a load binder. Make sure it is tight. Lock brakes on tractor. After driving 15-30 miles check load binders to see if still tight. re-tighten if necessary. Check ever so often for safety and arrive with it safely.
