Re: trailering an H
Posted by Andy Martin on December 28, 2007 at 19:18:20 from (63.99.111.185):
In Reply to: trailering an H posted by j440 on December 28, 2007 at 17:01:45:
It is important to recognize you need the chains most when you are in a panic stop. Unless local laws require otherwise, one chain in front is enough but you should have two independent chains at the back holding the tractor from moving forward. I like to chain around the axle, an old drawbar can come off in an emergency and an H is too big to put in the cab with you.
Next step, take it slow and easy, giving yourself plenty of room to stop.
