Re: 3pt off of M bellypump
Posted by gene bender on December 29, 2007 at 04:04:59 from (67.55.226.214):
In Reply to: 3pt off of M bellypump posted by Randy McClenahan on December 28, 2007 at 19:04:43:
If you want the blade to work on two-way you need to add a two-way control valve in series to the cycl. Then by locking the belley pump lever back the two-way weill now control the blade with two-way action. Just remember with down pressure you mite raise the wheels up with the down pressure and the tractor wont move. Mite just want to run the blade with lift only and let the wt of the blade cut. But if you need the down pressure you will need the tw-way control valve.
