Re: Rebuilding super c engine
Posted by Dave S. on December 29, 2007 at 06:12:30 from (205.162.219.187):
In Reply to: Rebuilding super c engine posted by Indiana George on December 29, 2007 at 05:24:50:
It is the clearance between the rod and main bearing and the crankshaft without any oil applied when installed and torqued to specifications. Check clearance using a plastic gague between rod bearings, main bearings and crankshaft and torque to spec but to not turn crank while doing this(do one at a time). Remove cap measure clearence, remove squashed plastic gague apply lube and reinstall cap.
To do the camshaft measure the shaft with a outside micrometer and the inside of the bearing with a inside micrometer. The difference between the two is the running clearance.
