pto mounting bolt pattern smta/110 balanced mower?
Posted by twopills on December 29, 2007 at 09:26:16 from (98.17.198.39):
We are trying to mount 110 balanced sickle bar mower to smta. There is a rear shield that mounts to the independant pto unit and becomes the mounting bracket for the driven sprocket on the mower unit. We haven't been able to figure out which mounting bolts from rear pto housing match up to mounting plate. Should it be 2, 3, or 4 bolt pattern? It also appears spacers are required to clear the compression spring housing for engagement lever. Does anyone know/remember?
