You can connect the battery cable to the starter solenoid if it has one like this. You may need to install another battery cable from solenoid to the starter. Make sure that tractor is out of gear. Then take a piece of insulated wire and just touch where your battery cable is connected to the solenoid and to the small terminal on the solenoid with an S. You will need to ground the battery on the tractor's frame. Make sure all rust and paint is removed for a good ground. Hal
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
