Posted by glennster on December 29, 2007 at 19:29:34 from (68.60.242.156):
In Reply to: 1206 560 Motors posted by ihdoug on December 29, 2007 at 19:10:53:
if it spun a bearing,chances are the crank needs to be cut, also you prolly got metal flakes from the bearing in the oiling system. if you are going to pull the crank, you're gonna need to split it. i looked at shoups, they have the overhaul kit for 1338.14, complete with bearings. figure a couple hundred to cut the crank, maybe couple hundred for the valve job, as long as the valves are still good, you'll have 2 g's in the motor ball park figure if you do the labor yourself.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
