Posted by Wardner on December 30, 2007 at 03:05:00 from (4.154.245.65):
In Reply to: B450 4WD posted by Mike Farmer on December 30, 2007 at 01:23:45:
It appears that the gearbox position is low enough that the power must come from the constant mesh reverse idler gear. I suppose all the B450s must have had the opening in the rear frame for that attachment.
This is in contrast to the Elwood front drive set-up on US made IH tractors (M thru 660). There is no side outlet in the rear frame and the power comes off the top of one of the mainshaft slider gears: probably 4th-5th.
I am no authority on other makes, but I think contemporary Oliver and Minneapolis-Moline both had the side outlet long before US made IH tractors.
Although there is no way to tell from the pictures, that tractor must have had power steering but no TA.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
