Posted by gene bender on December 30, 2007 at 12:36:56 from (67.55.226.214):
In Reply to: Super C hydraulics posted by farrell(Utah) on December 30, 2007 at 12:12:57:
If the unit was dry the engine was working that means the pump had no fluid to circulate. If that is the case the pump is probably shot. You mite want to remove a plug on the pump and fill with oil this just mite prime the pump. After starting the engine listen to the pump it should make a noise and you mite need to srop the engine and re-prime the pump and then restart. If you still dont hear any noise from the pump mite as well drain the res and remove the pump as it could be ruined by not having any oil to keep it lubed and we can go from there.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
