Re: John T; Super A Charging, needs flash; Followup
Posted by gene bender on December 30, 2007 at 15:40:26 from (67.55.226.214):
In Reply to: John T; Super A Charging, needs flash; Followup posted by scott#2 on December 30, 2007 at 15:03:34:
I would ground the field then see what the volts read at the arm post on the gen. If grounding the field makes it charge your reg is bad or you need a better ground somewhere.
