Re: John T; Super A Charging, needs flash; Followup
Posted by John T on December 30, 2007 at 15:58:03 from (66.244.83.147):
In Reply to: John T; Super A Charging, needs flash; Followup posted by scott#2 on December 30, 2007 at 15:03:34:
If you dead ground the gennys FLD post thats her max charge assuming the gennys has a good ground n the belts tight n the wiring is all okay n the cutout relay is also fine. So if shes still a weak charger and the battery isnt at fault like a bad cell then its genny repair time like brushes or brush hold downs or bushings or commutator or armature etc.
John T
