Hi Migraine, High idle is 1650 so you don't have an rpm problem. Did you get the fuel system bled good, air could cause that, if not air the primary pump may be weak. Open the bleeder valve on each injector one at a time to find which cylinder is missing. I doubt it would be the starting valves but if you have a book there is a check an adjust sequence to follow on the starting system which would be a good idea. Good luck, Chuck
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
