Re: Super A Dead Battery
Posted by El Toro on December 31, 2007 at 03:53:31 from (205.188.116.73):
In Reply to: Super A Dead Battery posted by John Franklin on December 31, 2007 at 03:30:23:
You should have the old battery tested. If it has a dead cell or won't accept a charge replace it. Reinstall the new battery and see if the engine will start. If it starts take a volt meter and check the charging voltage at the battery. You should have charging voltage in the 7.2 to 7.5 range. Make sure you clean all battery connections until they're shiny. Clean the area where your battery is grounded too. Hal
