Re: Water
Posted by El Toro on December 31, 2007 at 04:02:18 from (205.188.116.73):
In Reply to: Water posted by Kristof on December 31, 2007 at 03:28:37:
You should check or have the head checked for flatness. It may be warped. When torquing the head start in the center and tighten in both directions. Start with about 30 ft-lb and keep increasing the torque until you reach the recommended torque. Run the engine and get it hot
and then retorque it again. I would check the valve lash too to see if it has changed. Hal
