Re: Water
Posted by caterpillar guy on December 31, 2007 at 04:48:28 from (205.188.116.73):
In Reply to: Water posted by Kristof on December 31, 2007 at 03:28:37:
Get a parallel it is a straight edge but is not like the square or what ever you have been using for the guage on the block they are used in machine shops for just this purpose with a feeler guage try to slip it under the parallel if you can the block needs to be milled do the same with the head. Then I just use grease gun grease on the head gaskets I put on and never been an issue. Any machine shop worth their salt should have a parallel if you have the block milled they will have to cut the counter bore for the sleeve.
