Re: radiator replacement in an H
Posted by RustyFarmall on December 31, 2007 at 04:49:27 from (209.152.78.71):
In Reply to: radiator replacement in an H posted by Doug Campbell on December 30, 2007 at 17:33:01:
A 1948 H SHOULD have already had the late style, pressurized radiator, but since you say the old cap will not fit the new radiator, and also there is a difference in the overflow tube, I"m going to guess that the old radiator you took off is of the old, non-pressurized style, and is NOT what should have been there. The caps are different, the overflow tubes are different, and there is even a slight difference in the opening in the grill where the radiator neck comes through. If you do have the old style grill, it can be modified a bit and made to work.
