Posted by Andy Martin on December 31, 2007 at 06:08:35 from (63.99.111.177):
In Reply to: Re: Water posted by Kristof on December 31, 2007 at 05:42:30:
Scratches won't be your problem. Sealers like paint might help but are not necessary. The head gasket will deform to match the surface. You have some other problem.
How good was the shop that milled the head? They may have screwed it up. You should check it with a flat edge, only because you are having a persistent problem. A machinist's straight edge is good but you should be able to detect light under a carpenter's framing square if the square is pretty straight.
Check the bolts carefully and see if the threads look like they are damaged at the bottom from bottoming out. If your head was milled quite a bit it will be thinner, causing the bolts to go deeper in their holes. They may be hitting rusted up threads. This can be fixed by grinding off the ends of the bolts or by adding washers (trimmed to fit).
Did you start the engine and get it good and hot, then retorque the head?
Did you check your torque wrench? I have a broken one I loan out. It seems to work OK but consistently reads low. It was OK when I first loaned it out, so I keep it for a loaner.
I've never had a warped block so that is what I would check last.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
