Posted by CityBoy-McCoy on December 31, 2007 at 07:03:35 from (209.214.107.109):
In Reply to: Water posted by Kristof on December 31, 2007 at 03:28:37:
Kristof: I don't know if this will help in your situation, however for what it may be worth.... You mentioned corrosion around the water channels. I owned an outboard business on the Florida Gulf Coast for years. We often had big outboards come into the shop which had been used only in salt water for 20 years with no flushing. Sometimes a big V-6 would come in with a blown head gasket and we would find salt corrosion had eaten away the sealing surface between the water jacket and the cylinder wall casting - that there was basically nothing left except the top edge of the sleeve itself for a sealing surface against the head (the aluminum portion was erroded away). We would clean up the area, mix up some two part epoxy, and apply the epoxy to the erroded area as we installed the head gasket and cylinder head. The only alternative was to junk the block, or the entire outboard motor. I never saw an instance in 7 years where that fix did not work and hold well, even under compression readings of 125-140 psi. The epoxy we used was made for OMC/Bombardier for gluing the magneto magnets inside flywheels, so it was heat resistant. But I would imagine JB Weld would work about as well. mike durhan
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
