Re: How about this rebuild kit?
Posted by RustyFarmall on December 31, 2007 at 07:19:53 from (209.152.78.71):
In Reply to: How about this rebuild kit? posted by michael price on December 31, 2007 at 06:39:27:
You need to tear your engine down and inspect it before buying a kit. I know that kit comes with everything, but you may need undersized bearings to compensate for wear on the crankshaft, or maybe even the crank will need to be turned down at a machine shop. More than likely the rod bushings will also need to be replaced, and then those need to be reamed to the correct size for the new pins. You might want to consider buying a kit without the bearings, and let your local machine shop get those for you. If the machine shop gets to sell you the bearings, he will probably inspect and measure the crankshaft for free.
