Re: Screaming 886
Posted by georgeky on December 31, 2007 at 10:21:06 from (205.188.116.73):
In Reply to: Screaming 886 posted by Fred the Swede on December 31, 2007 at 09:18:36:
You sure it isn't an engine bearing? May be fuel in the oil causing it. I had one that done the same thing. It was the rear main bearing screaming.
