Re: Water
Posted by MN Scott on December 31, 2007 at 11:23:50 from (206.9.216.48):
In Reply to: Re: Water posted by Kristof on December 31, 2007 at 05:42:30:
The instructions that came with my Super H gasket set said to coat gasket with copper coat or aluminum paint. You should be using a coating on your super C. Also the tourque on the head bolts has been up dated to 80 Ft Lbs. If your gasket is just seeping a bit I would just take the tractor out and work it and get it good and hot. I have had 706 gas new head gaskets seep a fair amount and I took them out and worked them and they all stopped leaking.
