Posted by El Toro on December 31, 2007 at 11:28:34 from (205.188.116.73):
In Reply to: Electrical on M-F posted by Levi Keech on December 30, 2007 at 17:36:57:
There has to be a hot wire feeding voltage to your switch. Some of these tractors have battery voltage fed from the starter solenoid to the ignition switch. Most cars and trucks are set up that way too. Most of the solenoids have 2 small terminals. One terminal is marked with an S for the starter. It only has voltage when you are cranking the engine. The other small terminal will have voltage all the time so it can supply voltage to your ignition if its a gas engine, to your lights when you need them and to the starter when you want to crank the engine. I would examine those wires closely for any signs of being hot. Hal PS: Here's a solenoid picture.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
