Re: 560 carb problems
Posted by I love farmalls on December 31, 2007 at 12:39:22 from (207.199.208.48):
In Reply to: 560 carb problems posted by 560 owner in KS on December 31, 2007 at 12:10:50:
For winter use I made a heat exchanger. I took a piece of duct pipe about 10" in diameter,put a 'lid' or metal cap on one end and put a hole in it so the exhaust pipe will fit through and slide down to the muffler, then on the side of 10" pipe, I mounted a about a 4' flexable exhaust pipe to reach the air cleaner pipe after you remove the precleaner. That way it sucks the warmer air off the warm muffler. Been doing it for 20 years.
