Re: 560 carb problems
Posted by old on December 31, 2007 at 14:21:16 from (4.244.90.252):
In Reply to: 560 carb problems posted by 560 owner in KS on December 31, 2007 at 12:10:50:
Would you believe that iceing like that is normal and all carbs do it. Worst when its cold and or wet out but its just how it is. It doesn't happen as much on cars and trucks because of the heat tube from the manifold and also because of the hood holding heat in but a tractor has open sides so the heat goes bye bye fast. Things you can do to make it happen less is a tarp over the engine/hood. Or some other type of thing rigged up to help hold the heat around the carb. Or just let it run 10-15 minutes before you work it hard so the manifold get a chance to warm up.
