Re: Hydraulic dipstick missing on H
Posted by glennster on December 31, 2007 at 15:48:51 from (68.60.242.156):
In Reply to: Hydraulic dipstick missing on H posted by Guyzoo on December 31, 2007 at 14:52:41:
you prolly need the seal where the drive dog goes into the housing and the housing gasket. pretty easy to change, you need to drop the pump, seperate it from the housing, slide a piece of flat stock in the pump gears, then tap the dog counterclockwise, it will unscrew, new seal there, put the new gasket on, line up the fork when you put the halves back together. takes maybe an hour or 2.
