Re: Last Day drove my Farmall
Posted by Andy Motteberg on December 31, 2007 at 22:51:03 from (4.143.216.88):
In Reply to: Last Day drove my Farmall posted by Michael Hale on December 31, 2007 at 22:33:22:
They don't always start well in the cold. Sometimes they make noise in the transmission because the gear lube is thicker in the cold. Be sure you are using 80-90 gear lube. I could not veiw your video because my PC is too slow.
Andy.
