Re: M axle seals
Posted by Haas on January 01, 2008 at 07:13:55 from (12.65.24.61):
In Reply to: M axle seals posted by Pepper boy on January 01, 2008 at 06:29:12:
I did this a few years ago to my MD. One of them still leaks. The seal has to slide all the way in from the end of the axle when you reinstall the axle cap. Therefore, make sure the axle is clean and smooth so you don't damage the seal. It's not a bad job but you need help, or some lifting equipment to get the rims, weights (if you have them) and hubs off. I found the retainer bolts in the axle clamps were a bit stubborn. No problems other than that the one still leaks.
