George, The low voltage current switching portion of the distributor (points and condensor) is NOT a particular voltage sensitive or caring device ITS JUST A CURRENT SWITCH to conduct the coils current (regardlss if 6 or 12 volt coil) when points are closed and break it when they are open on high cam.
The points and condensor dont know or care so much about voltage so long as its not so high it would cause points or condensor failure. The voltage withstand ratings of the points n condensor is wayyyyyyyyyyy higher then merely 6 or 12 volts anyway. They dont make a distributor to handle only 6 volts while another one can handle 12 THEY ARE THE SAME and switch the coils approximate 4 amps REGARDLESS if its a 6 or 12 volt coil. The voltage rating of the points n condensor is more like in the hundreds of volts NOT only a mere 6 or 12. The distributor will work n dont care if you have a 6 or 12 volt tractor or coil ITS JUST A SWITCH THAT closes when points close n opens when they are open and can do that regardless if theres 1 or 6 or 12 or 50 voltsat its input terminal/stud
SO AGAIN A distributor IS NOT a 6 or 12 volt distributor THEY ARE THE SAME N DONT KNOW OR CARE. When you convert from 6 to 12 volts you for sure DO NOT have to change or convert the distributor !!!!!!!!!!! Its ONLY a current switch and it and its points n condensor can withstand wayyyyyyyyyyyyyy higher then 6 or 12 anyway.
AGAIN a 6 volt coil is NOT a 12 volt coil, see my post above so if anyone tries to tell you different they are just plain WRONG
Hope this helps n dont be worried if you cant understand what a person does who has a lifetime od training n experience can. Great questions n I hope you understand this.......
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
