Posted by D Slater on January 01, 2008 at 15:43:08 from (72.65.139.197):
In Reply to: 300U TA ???? posted by Vt-Woodchuck on January 01, 2008 at 07:37:19:
The short lever with the rod going forward to clutch linkage (on side of case behind clutch pedal arm and between starter and battery in picture) is on the end of a shaft that operated the T/A clutch. Yes it had or has a T/A inside. If the T/A clutch is still in there and it and the clutch and release bearing good you can adjust the link between clutch and shaft to help with hard to get out of gear problem, if thats the problem. don't shorten link so much that release bearing contacts t/a clutch pressure plate unless clutch is pushed. If there's no spring to pull the t/a shaft clockwise, add one.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
