240 fast hitch ??
Posted by glennster on January 02, 2008 at 07:59:00 from (76.224.13.122):
still fooling around with the 240utility. have some fast hitch issues. heres what happens. pull back on the control, hitch lowers, foreward on control, hitch raises, however, hitch will strain on the up cycle, you need to lower and raise couple times, then it comes up fine. i switched the hydraulic hoses at the cylinder, and the hitch works fine with no strain, however, the hitch then creeps down. under the seat is a junction block that the hoses connect to. is there a check valve in there? are they rebuildable? here is a pic of the block
third party image
