Re: Farmall 450 dying
Posted by glennster on January 02, 2008 at 08:35:27 from (76.224.13.122):
In Reply to: Farmall 450 dying posted by Tractordummy on January 02, 2008 at 08:07:08:
when you say it loses all electrical power, do you loose the lights and everything? if so and the battery doesnt need a charge after an hour of sitting, sounds like a bad connection somewhere. get a 12volt test lite and start tracking down the electrical system. when the tractor dies, and wont restart, go to the ignition coil and check there for voltage. if there is none present, start following that wire back thru the loom and check all connections till you get to the battery. clean and check both battery terminals, recheck battery ground cable to chassis. it may also be a problem with the ignition switch too.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
