Posted by EK in MO on January 02, 2008 at 09:00:36 from (75.61.10.219):
In Reply to: Farmall 450 dying posted by Tractordummy on January 02, 2008 at 08:07:08:
Had this same problem on a Ford 961. Had a loose connection on the electrical block just past the switch. Cleaned and tightened the connections and fixed the problem. Don't know if the 450 has the same type of wiring block but would look for where the wiring splits off after the switch.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and
... [Read Article]
Latest Ad:
[More Ads]
