Re: Farmall 450 dying
Posted by old on January 02, 2008 at 09:17:38 from (4.244.90.130):
In Reply to: Re: Farmall 450 dying posted by Tractordummy on January 02, 2008 at 08:27:06:
Ok fill in the blanks some. You say when it dies you have no power but is it no power or no spark?? Big difference in the 2. Will it turn the engine over just no start or does it every thing go out on you?? If you just loose spark then its most likely your coil is going bad. A bad coil will work just fine for about and hour and then stop working as it heats up. Start it up, run it till it dies and then jump off and check for spark and also lay your hand on the coil and see if its hot, be careful it could be hot enough to burn you if the coil is going bad. When you ask question you always need to give us as much info as you can so we can help you with out trying to read your mind
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
