Re: putting a Farmall 300 rear case into a Farmall H
Posted by Armand Tatro on January 02, 2008 at 13:35:53 from (67.176.252.97):
In Reply to: putting a Farmall 300 rear case into a Farmall H posted by az tractor guy on January 02, 2008 at 13:04:14:
It is possible to weld a patch to the case and than seal the inside and outside of the patch with a sealer and you should not have any seepage. We had to have the case patched and welded on an Farmall M in about 1962 and it is still holding. Had a hole bigger than my fist and there are better sealers avaible today. Armand
