Re: 6 of 12 v coil
Posted by old on January 02, 2008 at 15:18:18 from (4.244.186.116):
In Reply to: 6 of 12 v coil posted by percy on January 02, 2008 at 14:24:33:
I'm like Goe. I can't say for sure but it probably needs to have one. Do you still have that car?? If you do just look on the fire wall for a ballast resister if it has one then you need one if it doesn't then you don't need one. Or call a dodge dealer and ask if it uses a ballast resister on that type of car, if it does then ask them for one or call your local auto parts store and get one
