Posted by Janicholson on January 02, 2008 at 15:25:30 from (66.173.50.38):
In Reply to: 6 of 12 v coil posted by percy on January 02, 2008 at 14:24:33:
A Horizon will be an electronic ignition coil. If the coil is not getting hot when running for an hour, (so hot you can't put your hand on it) then I would leave it alone. If the points are not burning out in abnormally short intervals, it is just fine. Some transistor ignitions use resistor wire within the loom, others use a resistor block, others use no resistor at all. The dealer would know. JimN
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
