Re: F-20 frame
Posted by Scott Rukke on January 02, 2008 at 16:55:29 from (67.183.230.71):
In Reply to: Re: F-20 frame posted by ejr-IA on January 02, 2008 at 13:20:46:
Tubing only refers to the shape. Structural square, rectangular and round steel is called tubing. It in no way signifies the wall thickness or strength of the steel. Your car frame is made of tubing or channel.
The definition from Wikipedia:
Tubing is a pipe or hollow cylinder for the conveyance of fluids (liquids or gases). The terms 'pipe' and 'tubing' are almost interchangeable, although minor distinctions exist (generally, "tubing" implies tighter engineering requirements than "pipe"). Both "pipe" and "tube" imply a level of rigidity and permanence, whereas a "hose" is usually portable and flexible. Tubing and pipe may be specified by standard pipe size designations, e.g. Nominal Pipe Size — or by nominal outside or inside diameter and/or wall thickness. The actual dimensions of pipe are usually not the nominal dimensions (i.e., a "1-inch" pipe will not actually measure 1" in either outside or inside diameter) — whereas many types of tubing are specified by actual I.D., O.D., and/or wall thickness. There are many industry and government standards for pipe and tubing.
