Re: frame twist
Posted by Janicholson on January 02, 2008 at 18:47:33 from (66.173.50.168):
In Reply to: frame twist posted by 52 G on January 02, 2008 at 18:24:41:
On open Chanel frames, the primary torsion resistance is the bolting into the castings. If these ar at all loose, or the threads are abused and torquing does not result in proper pinching of the frame, there will be twist. I would pull bolts (one at a time) and make sure they are correctly pinching the frame. Others may be more objective, My experience is with an Alis Chalmers WD. JimN
