Re: HYDROLIC PUMP BETWEEN DISTRIBUTER AND ENGINE
Posted by glennster on January 02, 2008 at 18:54:02 from (68.60.242.156):
In Reply to: HYDROLIC PUMP BETWEEN DISTRIBUTER AND ENGINE posted by SD FARMALL on January 02, 2008 at 18:24:47:
i am going to take a guess and say you are probably working on an h or m. the most common aftermaket power steering kits available were the char-lynn and the behlen set ups. the char lynn had a pump that ran off the generator belt. the behlen pump mounted directly behind the distributor. it replaces the small housing so in effect you could run the i-h live pump, then the behlen pump, then the distributor. the torque generator mounted in the steering shaft as did the char-lynn. with a priority flow valve, you can run the char-lynn from the i-h live pump. the behlen was pretty much all self contained. there is some posts a few pages back, scan for behlen power steering, as somebody posted pictures of their set up.
