Re: HYDROLIC PUMP BETWEEN DISTRIBUTER AND ENGINE
Posted by SD FARMALL on January 02, 2008 at 19:30:37 from (69.77.194.186):
In Reply to: Re: HYDROLIC PUMP BETWEEN DISTRIBUTER AND ENGINE posted by CNKS on January 02, 2008 at 19:20:50:
third party image
third party image
third party image
I'm trying to upload a couple of pictures one of the pump and one of the assist cylinder. My big question is will it work to run the pump straight to the cylinder or will i have to get a valve that reduces the pressure?
